joshuatharp
sad I’m frustrated
Upgrading from Basic to Pro 4.4 errors at database import
I am upgrading from ScrumWorks Basic to ScrumWorks Pro 4.4 on a RHEL server. I am following the instructions here: http://danube.com/docs/scrumworks/pro.... I'm using: scrumworks-pro-4.4.0-mac_linux-mysql.tar.bz2
I run the setup.sh script and answer the questions:
* Where is Java? - /usr/java/jdk1.6.0_21
* Run as daemon? - y
* Run as user? - apache
* Run as group? - apache
* Upgrade? - y
* Path to old "ScrumWorks Pro" installation? - /usr/local/scrumworks-1.8.3
* Correct? - y
I get the output:
Installing Jakarta Commons HttpClient 3.1...
Installing Apache POI - Java API To Access Microsoft Format Files...
Installing sample database...
Changing permissions...
Configuration file created.
Stopping existing ScrumWorks service...
Running the upgrader...
Installing on Linux
Java 6 SDK was found. Continuing...
The databases in both versions of ScrumWorks must be of the same type.
An error occurred while updating your database.
this problem
