I have installed a copy of scrumworks pro 5.1 on a vm running win server 2003 r2. The service is running, but when I go to http://localhost:8080/scrumworks I get a 404 not found.
I also have a copy of VisualSVN running (as a mirror to a collabnet svn server) on the same machine using apache 2.0.6.
Any ideas on how I can get scrumworks running in the web browser?
Additional info: I have reinstalled scrumworks with the same results. Apache was already on the machine. The scrumworks install did a lot of downloading that looked like it was addressing what I see in the log.
The server log contains:
2012-01-25 14:02:28,314 ERROR [ProfileServiceBootstrap] (Thread-2) Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
DEPLOYMENTS MISSING DEPENDENCIES:
Deployment "AdminConsoleActivator" is missing the following dependencies:
Dependency "WebServer" (should be in state "Installed", but is actually in state "**ERROR**")
Deployment "JBossWSConsoleActivator" is missing the following dependencies:
Deployment "JmxConsoleActivator" is missing the following dependencies:
Deployment "ModClusterListener" is missing the following dependencies:
Dependency "WebServer" (should be in state "Create", but is actually in state "**ERROR**")
Deployment "jboss.web.deployment:war=/" is missing the following dependencies:
Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "** NOT FOUND Depends on 'jboss.web:service=WebServer' **")
Deployment "jboss.web.deployment:war=/invoker" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/scrumworks" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/scrumworks-api" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/scrumworks-api/api2" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/swjars" is missing the following dependencies:
DEPLOYMENTS IN ERROR:
Deployment "WebServer" is in error due to the following reason(s): LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind /0.0.0.0:8080, **ERROR**
Deployment "jboss.web:service=WebServer" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.web:service=WebServer' **
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:1228) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainDeployerImpl.java:905) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.checkComplete(MainDeployerPlugin.java:87) [:6.0.0.Final]
at org.jboss.profileservice.deployment.ProfileDeployerPluginRegistry.checkAllComplete(ProfileDeployerPluginRegistry.java:107) [:0.2.2]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:135) [:6.0.0.Final]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:56) [:6.0.0.Final]
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:827) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:417) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at java.lang.Thread.run(Unknown Source) [:1.6.0_26]
2012-01-25 14:02:28,314 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-2) JBossAS [6.0.0.Final "Neo"] Started in 3m:44s:235ms -
It looks like your install was corrupted.
Trying doing an "offline" install. Please place the install file in a folder with the files found here: http://www.danube.com/docs/scrumworks...
Then run the installer. This will bypass the installers need for network access.
Be sure to fully uninstall all previous copies of Scrumworks before reinstalling. Or try this on a separate test machine. -
