Help get this topic noticed by sharing it on Twitter Twitter, Facebook Facebook, or email.
Marco Berger
Scrumworks startup
Debian 6 Scrumworks Installation, sun-java 1.6.0.26 following error on scrumworks startup (right after the installation):
INFO [DefaultListableBeanFactory] Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@69e7daa2: defining beans [org.springframework.security.web.PortMapperImpl#0,org.springframework.security.web.context.HttpSessionSecurityContextRepository#0,org.springframework.security.web.authentication.session.SessionFixationProtectionStrategy#0,org.springframework.security.authentication.ProviderManager#0,org.springframework.security.web.access.expression.DefaultWebSecurityExpressionHandler#0,org.springframework.security.access.vote.AffirmativeBased#0,org.springframework.security.web.access.intercept.FilterSecurityInterceptor#0,org.springframework.security.web.access.DefaultWebInvocationPrivilegeEvaluator#0,org.springframework.security.authentication.AnonymousAuthenticationProvider#0,org.springframework.security.authentication.RememberMeAuthenticationProvider#0,org.springframework.security.web.savedrequest.HttpSessionRequestCache#0,org.springframework.security.web.authentication.UsernamePasswordAuthenticationFilter#0,org.springframework.security.config.http.UserDetailsServiceInjectionBeanPostProcessor#0,org.springframework.security.filterChainProxy,org.springframework.security.authentication.DefaultAuthenticationEventPublisher#0,org.springframework.security.authenticationManager,rememberMeServices,jaasNameCallBackHandler,jaasAuthenticationProvider,userDetailsService,jbossSecurityFilter,authSuccessHandler,scrumworksRedirectStrategy,ajaxAuthenticationEntryPoint,formAuthenticationEntryPoint,authenticationChooser]; root of factory hierarchy
19:26:50,871 ERROR [ContextLoader] Context initialization failed: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.security.authentication.ProviderManager#0': Cannot create inner bean '(inner bean)' of type [org.springframework.security.config.authentication.AuthenticationManagerFactoryBean] while setting bean property 'parent'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name '(inner bean)': FactoryBean threw exception on object creation; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.security.authenticationManager': Cannot resolve reference to bean 'jaasAuthenticationProvider' while setting bean property 'providers' with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jaasAuthenticationProvider' defined in ServletContext resource [/WEB-INF/spring/applicationContext-security.xml]: Cannot resolve reference to bean 'jaasNameCallBackHandler' while setting bean property 'callbackHandlers' with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'jaasNameCallBackHandler' defined in ServletContext resource [/WEB-INF/spring/applicationContext-security.xml]: Cannot resolve reference to bean 'userDetailsService' while setting bean property 'userDetailsService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'userDetailsService' defined in ServletContext resource [/WEB-INF/spring/applicationContext-security.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [com.danube.scrumworks.web.authentication.ScrumWorksUserDetailsService]: Constructor threw exception; nested exception is java.lang.LinkageError: loader constraint violation: loader (instance of org/jboss/web/tomcat/service/WebCtxLoader$ENCLoader) previously initiated loading for a different type with name "com/danube/scrumworks/team/UserTO"
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:281) [:3.0.5.RELEASE]
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:125) [:3.0.5.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1325) [:3.0.5.RELEASE]
this question
  • (some HTML allowed)
    How does this make you feel?
    Add Image
    I'm
    e.g. sad, anxious, confused, frustrated kidding, amused, unsure, silly indifferent, undecided, unconcerned happy, confident, thankful, excited
  • It is not an error that I have seen before. If you would be willing to send me your sever.log file I can take a look and see if we can find (mlovell@collab.net).
    What version of JDK are you using?
    Also, there are a lot of security references in that error. Is the account being used for Scrumworks on that system a full admin account?
    Add Image
    I'm
  • janich
    Hi!
    I'm have also this problem.
    I'm trying install ScrumWorks Pro 5.1.0 on OpenSUSE 11.4 (64bit).
    I have Java SDK 1.6.0.30.
    I'm trying install both version of SQL-driver compatible (MySQL and HSQL).
    And I have error:
    And I have this strings in error log at he end:
    11:39:28,533 ERROR [ProfileServiceBootstrap] Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
    DEPLOYMENTS IN ERROR:
    Deployment "jboss.web.deployment:war=/scrumworks" is in error due to the following reason(s): org.jboss.deployers.spi.DeploymentException: URL file:/home/admin/projects/scrum/scrumworks-5.1.0/server/scrumworks/tmp/vfs/automount56f62b3e8dc92117/spring-app.war-81cb977b1884d1f8/ deployment failed
    at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:1228) [:2.2.0.GA]
    at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainDeployerImpl.java:905) [:2.2.0.GA]
    at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.checkComplete(MainDeployerPlugin.java:87) [:6.0.0.Final]
    at org.jboss.profileservice.deployment.ProfileDeployerPluginRegistry.checkAllComplete(ProfileDeployerPluginRegistry.java:107) [:0.2.2]
    at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:135) [:6.0.0.Final]
    at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:56) [:6.0.0.Final]
    at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:827) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
    at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:417) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
    at java.lang.Thread.run(Thread.java:662) [:1.6.0_30]
    11:39:28,584 INFO [org.apache.coyote.http11.Http11Protocol] Starting Coyote HTTP/1.1 on http-0.0.0.0-8180
    11:39:28,587 INFO [org.apache.coyote.ajp.AjpProtocol] Starting Coyote AJP/1.3 on ajp-0.0.0.0-8109
    11:39:28,588 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] JBossAS [6.0.0.Final "Neo"] Started in 2m:20s:36ms
    Please, help me in this problem.
    Add Image
    I'm
  • Does the computer you are installing Scrumworks onto have full internet access without a proxy in use?
    • This computer don't have internet access. I'm download all needed packages and put thems into directory with ScrumWorks. Installation process finished correctly. I have this problem while I'm starting ScrumWorks...
      But now I'm added internet access to this computer and reinstall program. Results is the same...
      Do you think about this?
    Add Image
    I'm
  • There some issues with a previous version of our installation/upgrade software when a non internet connected machine was used. I would suggest you fully remove the failed install, and that you download a fresh copy of our installer and give it another try.
    Add Image
    I'm
  • janich
    I think that installers ScrumWorksPro 5.1.0 and 4.5.1 (I'm also tryuing install this) has internal problems bacause I'm also tryuing install version 5.0.1 (32 bit) on Ubuntu 11.10 (32 bit)...
    Add Image
    I'm
