The issue is as follows - you cannot move a backlog item (via right-click > move > release) without scrumworks then scrolling down to the new location of the item. Specifically, we have an "obsolete" release item that we use to keep old backlog items that have become obsolete, and everytime anyone moves an item there it scrolls all the way to the bottom of a very long list and they have to scroll all the way back up. Either that, or to avoid the problem, a user will try to drag the item into the top of the "obsolete" release, but in that case we are reliant on the list's autoscroll when you approach the margin, which is slow/flaky. A workaround or fix would make many people here very happy. You could either turn it off entirely, or offer the option somewhere to turn it off.
I would also like to note that when we discussed this issue I provided a possible work around involving opening up 2 copies of the backlog, and moving the item from one window to the other. This action in ScrumWorks will not duplicate the item, it will instead re-prioritize it. The customer stated that this solution would not fully fix the issue as the issue usually occurs during meetings when there is a shortage of screen area.
