adam2011
sad I’m frustrated
Map Teamforge & Scrumworks Projects Null Error
I am trying to map my scrumworks and teamforge projects using eclipse, when I finish setting up the mapping it gives me a null error –
java.lang.NullPointerException
at com.collabnet.teamforge.api.tracker.TrackerFieldValueDO.getId(TrackerFieldValueDO.java:36)
at com.collabnet.teamforge.api.tracker.TrackerClient.setField(TrackerClient.java:1421)
at com.collabnet.teamforge.api.tracker.TrackerClient.setField(TrackerClient.java:1408)
at com.collabnet.ccf.teamforge.schemageneration.TFSoapClient.setField(TFSoapClient.java:121)
at com.collabnet.ccf.teamforge_sw.wizards.ProjectMappingWizard.setPbiTrackerFields(ProjectMappingWizard.java:703)
at com.collabnet.ccf.teamforge_sw.wizards.ProjectMappingWizard.access$4(ProjectMappingWizard.java:642)
at com.collabnet.ccf.teamforge_sw.wizards.ProjectMappingWizard$1.run(ProjectMappingWizard.java:160)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
this problem
