Help get this topic noticed by sharing it on Twitter Twitter, Facebook Facebook, or email.
Gary Bennison
JBOSS Webserver error after installation
Hi I recently installed Scrumworks pro on a windows 2008 Server and it was working. However someone installed Team City on to the server which stopped scrumworks from loading up. I uninstalled it and re-installed but it still will not work, I uninstalled Team City. re-installed scrumworks and it still doesn't work. extract of server log below. Looks to me that the JBOSS webserver is screwed. However I don't know much about Jboss.
2011-12-12 15:15:47,064 ERROR [ProfileServiceBootstrap] (Thread-2) Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
DEPLOYMENTS MISSING DEPENDENCIES:
Deployment "AdminConsoleActivator" is missing the following dependencies:
Dependency "WebServer" (should be in state "Installed", but is actually in state "**ERROR**")
Deployment "JBossWSConsoleActivator" is missing the following dependencies:
Deployment "JmxConsoleActivator" is missing the following dependencies:
Deployment "ModClusterListener" is missing the following dependencies:
Dependency "WebServer" (should be in state "Create", but is actually in state "**ERROR**")
Deployment "jboss.web.deployment:war=/" is missing the following dependencies:
Dependency "jboss.web:service=WebServer" (should be in state "Create", but is actually in state "** NOT FOUND Depends on 'jboss.web:service=WebServer' **")
Deployment "jboss.web.deployment:war=/invoker" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/scrumworks" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/scrumworks-api" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/scrumworks-api/api2" is missing the following dependencies:
Deployment "jboss.web.deployment:war=/swjars" is missing the following dependencies:
DEPLOYMENTS IN ERROR:
Deployment "WebServer" is in error due to the following reason(s): LifecycleException: Protocol handler initialization failed: java.net.BindException: Address already in use: JVM_Bind /0.0.0.0:8009, **ERROR**
Deployment "jboss.web:service=WebServer" is in error due to the following reason(s): ** NOT FOUND Depends on 'jboss.web:service=WebServer' **
at org.jboss.deployers.plugins.deployers.DeployersImpl.checkComplete(DeployersImpl.java:1228) [:2.2.0.GA]
at org.jboss.deployers.plugins.main.MainDeployerImpl.checkComplete(MainDeployerImpl.java:905) [:2.2.0.GA]
at org.jboss.system.server.profileservice.deployers.MainDeployerPlugin.checkComplete(MainDeployerPlugin.java:87) [:6.0.0.Final]
at org.jboss.profileservice.deployment.ProfileDeployerPluginRegistry.checkAllComplete(ProfileDeployerPluginRegistry.java:107) [:0.2.2]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:135) [:6.0.0.Final]
at org.jboss.system.server.profileservice.bootstrap.BasicProfileServiceBootstrap.start(BasicProfileServiceBootstrap.java:56) [:6.0.0.Final]
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:827) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:417) [jboss-bootstrap-impl-base.jar:2.1.0-alpha-5]
at java.lang.Thread.run(Unknown Source) [:1.6.0_26]
2011-12-12 15:15:47,064 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-2) JBossAS [6.0.0.Final "Neo"] Started in 2m:2s:685ms
2011-12-12 15:38:27,743 INFO [STDOUT] (Thread-1) Posting Shutdown Request to the server...
2011-12-12 15:38:27,758 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-15) Stopping: JBossAS [6.0.0.Final "Neo"]
2011-12-12 15:41:08,095 ERROR [ProfileServiceBootstrap] (Thread-2) Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
2011-12-12 15:41:08,095 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-2) JBossAS [6.0.0.Final "Neo"] Started in 2m:17s:841ms
2011-12-13 03:29:09,488 INFO [STDOUT] (Thread-1) Posting Shutdown Request to the server...
2011-12-13 03:29:09,488 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-15) Stopping: JBossAS [6.0.0.Final "Neo"]
2011-12-13 03:33:57,708 ERROR [ProfileServiceBootstrap] (Thread-2) Failed to load profile:: org.jboss.deployers.client.spi.IncompleteDeploymentException: Summary of incomplete deployments (SEE PREVIOUS ERRORS FOR DETAILS):
2011-12-13 03:33:57,724 INFO [org.jboss.bootstrap.impl.base.server.AbstractServer] (Thread-2) JBossAS [6.0.0.Final "Neo"] Started in 3m:29s:185ms
this question
