How to redirect http to https?
I have configured ScrumWorks Pro to use https as instructed in the ScumWorks Pro user guides. Now I would like to have http to be redirected to https. This should be possible in by adding few lines to web.xml configuration file. However, In ScrumWorks Pro there are several web.xml files. Which one I should patch?
Hi Milja,
I have been doing some digging on this question, I don't actually have any specific documentation on this, nor has the question ever come up in the past. At least that I can find a record of.
After digging through all of the web.xml files I think there are one of two web.xml files that might be what you are looking for.
One is located at \server\scrumworks\deploy\jms\jbossmq-httpil.sar\jbossmq-httpil.war\WEB-INF\web.xml
and the other is \server\scrumworks\deploy\http-invoker.sar\invoker.war\WEB-INF\web.xml
Both of these web.xml files (and in fact most of the web.xml files I looked through) have comments denoting their use. I think if it is possible the first web.xml file above is most likely where it would be done.
Hopefully this is of some use to you. -
