How to delete an impediment?
How to delete an impediment? I didn't fin it in the user documentation and tried to find out in the UI but wothout success.
Hello!
In Scrumworks Pro, you will first need to make sure your user account has the permissions to edit/resolve impediments. The steps for resolving them can be found here:
http://danube.com/docs/scrumworks/pro...
For Scrumworks Basic you would want to follow the instructions found here:
http://www.danube.com/docs/scrumworks...
Currently you cannot delete an impediment completely from within the Client of either Basic or Pro. I believe this is the case in order to protect the history of the item. -
I'm a bit confused. So what you say is that the only way is to mark an impediment as resolved and undisplay the resolved ones. The documentation says Edit/Resolve/Delete while delete should not be in.
My use case is: I created a impediment by error and just want to delete it from the list. -
