Desktop Client's main window does not refresh on resizing
I Installed ScrumWorks Basic on Windows XP. There's a problem while running its Desktop client: When I resize its main window, it looks like the window does not refresh completely. Some elements do not display, some elements do not display at the correct place. How can I avoid this? Thanks for any clues.
Hi George,
I am unsure of exactly what is happening for you. I can't reproduce that on my system here. Hopefully one of our other Basic users can help? -
This can be easily reproduced on my machine: Just check the sub-menuitem 'Show Themes' of menu 'Themes'. After that, the window does not refresh correctly on resizing.
I find the way to fixed this problem:
You need use JDK 1.5 other than 1.6-
I user jdk 1.5-u22, the problem is not resolved.
Same problem here -- Ubuntu 10.04 + Sun JDK 1.6.0u23 + SW Basic 1.8.4 -- but the client works fine on my Windows XP machine w/ the same JDK version. Also, this happens when I first login, and dragging a dialog box over it doesn't repaint all the UI components either.
