x
You must log in to view that page.
Wu Ming
"Unable to launch the application" for ScrumWorks Pro 5.0
After upgrading ScrumWorks Pro 4.5.1 to ScrumWorks Pro 5.0, I started the desktop client with http://localhost:8080/scrumworks/, it reported error message "Unable to launch the application".
Here below is the information from the Exception tab:
com.sun.deploy.net.FailedDownloadException: Unable to load resource: (http://localhost:8080/scrumworks/jnlp..., 5.0.0)
at com.sun.deploy.net.DownloadEngine.actionDownload(Unknown Source)
at com.sun.deploy.net.DownloadEngine.getCacheEntry(Unknown Source)
at com.sun.deploy.net.DownloadEngine.getResourceCacheEntry(Unknown Source)
at com.sun.deploy.net.DownloadEngine.getResource(Unknown Source)
at com.sun.javaws.LaunchDownload$DownloadTask.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
And, here below is the Wrapped Exception:
java.io.IOException: cannot verify signature block file META-INF/SCRUMWOR
at com.sun.deploy.cache.CacheEntry$9.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.deploy.cache.CacheEntry.writeFileToDisk(Unknown Source)
at com.sun.deploy.cache.Cache.downloadResourceToTempFile(Unknown Source)
at com.sun.deploy.cache.Cache.downloadResourceToCache(Unknown Source)
And, here below is the records of server.log:
2011-08-03 20:24:29,780 DEBUG [org.jnp.server.NamingBeanImpl] Using NamingServer: org.jnp.server.NamingServer@7c22dcd4
2011-08-03 20:24:29,780 DEBUG [org.jnp.server.NamingBeanImpl] Installed global NamingServer: org.jnp.server.NamingServer@7c22dcd4
2011-08-03 20:24:29,796 DEBUG [org.jnp.server.NamingBeanImpl] InitialContext Environment:
2011-08-03 20:24:29,796 DEBUG [org.jnp.server.NamingBeanImpl] key=java.naming.factory.initial, value(java.lang.String)=org.jnp.interfaces.NamingContextFactory
2011-08-03 20:24:29,796 DEBUG [org.jnp.server.NamingBeanImpl] key=java.naming.factory.url.pkgs, value(java.lang.String)=org.jboss.naming:org.jnp.interfaces
2011-08-03 20:24:31,808 INFO [org.apache.catalina.startup.Embedded] Catalina naming disabled
2011-08-03 20:24:31,933 INFO [org.apache.catalina.core.AprLifecycleListener] The Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program\ScrumWorksPro\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\ActivIdentity\ActivClient\;C:\Program Files (x86)\ActivIdentity\ActivClient\;C:\Program Files (x86)\Hewlett-Packard\IAM\bin;C:\Java\jdk1.6.0_14\bin;C:\cygwin\bin;;.
2011-08-03 20:24:31,980 INFO [org.apache.coyote.http11.Http11Protocol] Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080
2011-08-03 20:24:31,980 INFO [org.apache.coyote.ajp.AjpProtocol] Initializing Coyote AJP/1.3 on ajp-0.0.0.0-8009
2011-08-03 20:24:31,980 INFO [org.apache.catalina.startup.Catalina] Initialization processed in 168 ms
2011-08-03 20:24:31,980 INFO [org.apache.catalina.core.StandardService] Starting service jboss.web
2011-08-03 20:24:31,980 INFO [org.apache.catalina.core.StandardEngine] Starting Servlet Engine: JBossWeb/2.0.1.GA
2011-08-03 20:24:32,026 INFO [org.apache.catalina.startup.Catalina] Server startup in 51 ms
2011-08-03 20:24:32,104 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/, warUrl=.../deploy/jboss-web.deployer/ROOT.war/
2011-08-03 20:24:32,650 INFO [org.jboss.ejb3.EJB3Deployer] Starting java:comp multiplexer
2011-08-03 20:24:32,806 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/invoker, warUrl=.../deploy/http-invoker.sar/invoker.war/
2011-08-03 20:24:34,538 INFO [org.jboss.wsf.stack.jbws.NativeServerConfig] JBoss Web Services - Native
2011-08-03 20:24:34,538 INFO [org.jboss.wsf.stack.jbws.NativeServerConfig] jbossws-3.0.1-native-2.0.4.GA (build=200803312044)
2011-08-03 20:24:34,616 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/jbossws, warUrl=.../deploy/jbossws.sar/jbossws-context.war/
2011-08-03 20:24:34,710 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/jbossmq-httpil, warUrl=.../deploy/jms/jbossmq-httpil.sar/jbossmq-httpil.war/
2011-08-03 20:24:35,490 INFO [org.jboss.mail.MailService] Mail Service bound to java:/Mail
2011-08-03 20:24:35,646 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-ha-local-jdbc.rar
2011-08-03 20:24:35,677 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-ha-xa-jdbc.rar
2011-08-03 20:24:35,739 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-local-jdbc.rar
2011-08-03 20:24:35,770 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jboss-xa-jdbc.rar
2011-08-03 20:24:35,802 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/jms/jms-ra.rar
2011-08-03 20:24:35,833 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/mail-ra.rar
2011-08-03 20:24:35,880 INFO [org.jboss.resource.deployment.RARDeployment] Required license terms exist, view META-INF/ra.xml in .../deploy/quartz-ra.rar
2011-08-03 20:24:35,880 INFO [org.jboss.resource.adapter.quartz.inflow.QuartzResourceAdapter] start quartz!!!
2011-08-03 20:24:35,942 INFO [org.quartz.simpl.SimpleThreadPool] Job execution threads will use class loader of thread: main
2011-08-03 20:24:35,973 INFO [org.quartz.core.QuartzScheduler] Quartz Scheduler v.1.5.2 created.
2011-08-03 20:24:35,973 INFO [org.quartz.simpl.RAMJobStore] RAMJobStore initialized.
2011-08-03 20:24:35,973 INFO [org.quartz.impl.StdSchedulerFactory] Quartz scheduler 'DefaultQuartzScheduler' initialized from default resource file in Quartz package: 'quartz.properties'
2011-08-03 20:24:35,973 INFO [org.quartz.impl.StdSchedulerFactory] Quartz scheduler version: 1.5.2
2011-08-03 20:24:35,973 INFO [org.quartz.core.QuartzScheduler] Scheduler DefaultQuartzScheduler_$_NON_CLUSTERED started.
2011-08-03 20:24:36,332 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name 'java:DefaultDS'
2011-08-03 20:24:36,566 INFO [org.jboss.mq.server.jmx.Queue.A] Bound to JNDI name: queue/A
2011-08-03 20:24:36,566 INFO [org.jboss.mq.server.jmx.Queue.B] Bound to JNDI name: queue/B
2011-08-03 20:24:36,566 INFO [org.jboss.mq.server.jmx.Queue.C] Bound to JNDI name: queue/C
2011-08-03 20:24:36,566 INFO [org.jboss.mq.server.jmx.Queue.D] Bound to JNDI name: queue/D
2011-08-03 20:24:36,566 INFO [org.jboss.mq.server.jmx.Queue.ex] Bound to JNDI name: queue/ex
2011-08-03 20:24:36,582 INFO [org.jboss.mq.server.jmx.Topic.testTopic] Bound to JNDI name: topic/testTopic
2011-08-03 20:24:36,582 INFO [org.jboss.mq.server.jmx.Topic.securedTopic] Bound to JNDI name: topic/securedTopic
2011-08-03 20:24:36,582 INFO [org.jboss.mq.server.jmx.Topic.testDurableTopic] Bound to JNDI name: topic/testDurableTopic
2011-08-03 20:24:36,597 INFO [org.jboss.mq.server.jmx.Queue.testQueue] Bound to JNDI name: queue/testQueue
2011-08-03 20:24:36,628 INFO [org.jboss.mq.il.uil2.UILServerILService] JBossMQ UIL service available at : /0.0.0.0:8093
2011-08-03 20:24:36,660 INFO [org.jboss.mq.server.jmx.Queue.DLQ] Bound to JNDI name: queue/DLQ
2011-08-03 20:24:36,660 INFO [org.jboss.mq.server.jmx.Topic.scrumworks/ServerUpdatesTopic] Bound to JNDI name: topic/scrumworks/ServerUpdatesTopic
2011-08-03 20:24:36,660 INFO [org.jboss.mq.server.jmx.Topic.scrumworks/ProgramUpdates] Bound to JNDI name: topic/scrumworks/ProgramUpdates
2011-08-03 20:24:36,660 INFO [org.jboss.mq.server.jmx.Queue.scrumworks/notification] Bound to JNDI name: queue/scrumworks/notification
2011-08-03 20:24:36,753 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name 'java:JmsXA'
2011-08-03 20:24:37,299 INFO [org.jboss.resource.connectionmanager.ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=jdbc/ScrumWorksDS' to JNDI name 'java:jdbc/ScrumWorksDS'
2011-08-03 20:24:37,362 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/, warUrl=.../tmp/deploy/tmp6023770539596802034root-exp.war/
2011-08-03 20:24:37,455 WARN [org.jboss.wsf.container.jboss42.JAXWSDeployerHookPreJSE] Cannot load servlet class: jnlp.sample.servlet.JnlpDownloadServlet
2011-08-03 20:24:37,455 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/swjars, warUrl=.../deploy/swjars.war/
2011-08-03 20:24:37,720 INFO [org.jboss.deployment.EARDeployer] Init J2EE application: file:/C:/Program/ScrumWorksPro/server/scrumworks/deploy/ScrumWorks-5.0.0.ear
2011-08-03 20:25:22,733 INFO [org.jboss.ejb.EjbModule] Deploying ScrumWorksEJB
2011-08-03 20:25:23,384 ERROR [STDERR] SLF4J: The requested version 1.5.11 by your slf4j binding is not compatible with [1.5.5, 1.5.6, 1.5.7, 1.5.8]
2011-08-03 20:25:23,384 ERROR [STDERR] SLF4J: See http://www.slf4j.org/codes.html#versi... for further details.
2011-08-03 20:25:23,467 WARN [org.jboss.wsf.container.jboss42.JAXWSDeployerHookPreJSE] Cannot load servlet class: com.danube.scrumworks.controller.ResetController
2011-08-03 20:25:23,480 INFO [org.jboss.ejb.EJBDeployer] Deployed: file:/C:/Program/ScrumWorksPro/server/scrumworks/tmp/deploy/tmp8403259609340978637ScrumWorks-5.0.0.ear-contents/ScrumWorksEJB.jar
2011-08-03 20:25:23,516 WARN [org.jboss.wsf.spi.metadata.webservices.PortComponentMetaData] element in webservices.xml not namespace qualified: ScrumWorksEndpointPort
2011-08-03 20:25:23,602 INFO [org.jboss.wsf.framework.management.DefaultEndpointRegistry] register: jboss.ws:context=scrumworks-api,endpoint=ScrumWorksEJB
2011-08-03 20:25:23,677 INFO [org.jboss.web.tomcat.service.TomcatDeployer] deploy, ctxPath=/scrumworks-api, warUrl=.../tmp/deploy/ScrumWorks-5.0.0.ear-ScrumWorksEJB.jar2984796043445572820.war/
2011-08-03 20:25:24,891 WARN [org.jboss.ws.metadata.builder.jaxrpc.JAXRPCServerMetaDataBuilder] Adding wsdl targetNamespace to: {http://api.scrumworks.danube.com/Scru...
2011-08-03 20:25:25,672 INFO [org.jboss.wsf.stack.jbws.WSDLFilePublisher] WSDL published to: file:/C:/Program/ScrumWorksPro/server/scrumworks/data/wsdl/ScrumWorks-5.0.0.ear/ScrumWorksEJB.jar/ScrumWorksService.wsdl
2011-08-03 20:25:25,699 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.entity.PersistenceUnitDeployment
2011-08-03 20:25:25,702 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks with dependencies:
2011-08-03 20:25:25,702 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.jca:name=jdbc/ScrumWorksDS,service=DataSourceBinding
2011-08-03 20:25:25,704 INFO [org.jboss.ejb3.entity.PersistenceUnitDeployment] Starting persistence unit persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,393 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,396 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ScrumWorksAPIBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,396 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ImpedimentLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ThemeLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=CommentLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultThemeDAO,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProgramLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TeamLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DelegatingEpicServiceTOFinder,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=BacklogLogicBean,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,397 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseRankLogicBean,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultImpedimentDAO,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUserDAO,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductProgressLogicBean,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductLogicBean,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=UserLogicBean,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TaskLogicBean,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,398 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3
2011-08-03 20:25:30,400 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,400 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ScrumWorksEjb3Bean,service=EJB3 with dependencies:
2011-08-03 20:25:30,400 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=CommentLogicBean,service=EJB3
2011-08-03 20:25:30,400 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultReleaseDAO,service=EJB3
2011-08-03 20:25:30,400 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TaskLogicBean,service=EJB3
2011-08-03 20:25:30,401 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DelegatingEpicServiceTOFinder,service=EJB3
2011-08-03 20:25:30,401 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramDAO,service=EJB3
2011-08-03 20:25:30,401 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3
2011-08-03 20:25:30,401 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,401 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,401 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=AttachmentLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultAttachmentDAO,service=EJB3
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUserDAO,service=EJB3
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,403 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,405 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,405 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultAttachmentDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,405 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,430 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.attachment.DefaultAttachmentDAO ejbName: DefaultAttachmentDAO
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=BacklogLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SequenceLogicBean,service=EJB3
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultThemeDAO,service=EJB3
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=AttachmentLogicBean,service=EJB3
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultReleaseDAO,service=EJB3
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TaskLogicBean,service=EJB3
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:30,448 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3
2011-08-03 20:25:30,449 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,449 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SourceLogicBean,service=EJB3
2011-08-03 20:25:30,450 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,450 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,451 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,460 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.backlog.DefaultBacklogItemDAO ejbName: DefaultBacklogItemDAO
2011-08-03 20:25:30,468 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,468 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemParentHistoryEntryDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,469 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,474 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.backlog.DefaultBacklogItemParentHistoryEntryDAO ejbName: DefaultBacklogItemParentHistoryEntryDAO
2011-08-03 20:25:30,480 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,481 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SourceLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,481 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,486 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.backlog.source.SourceLogicBean ejbName: SourceLogicBean
2011-08-03 20:25:30,493 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,494 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultThemeDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,494 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,499 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.backlog.theme.DefaultThemeDAO ejbName: DefaultThemeDAO
2011-08-03 20:25:30,508 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,508 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ChangeLogLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,509 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,516 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.changelog.ChangeLogLogicBean ejbName: ChangeLogLogicBean
2011-08-03 20:25:30,525 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,526 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DailyNotificationTimer,service=EJB3 with dependencies:
2011-08-03 20:25:30,526 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TaskLogicBean,service=EJB3
2011-08-03 20:25:30,526 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,527 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.mdb.MDB
2011-08-03 20:25:30,529 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=NotificationMessageBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,529 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,536 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.changelog.NotificationMessageBean ejbName: NotificationMessageBean
2011-08-03 20:25:30,568 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,572 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=CommentLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,573 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUserDAO,service=EJB3
2011-08-03 20:25:30,574 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=UserLogicBean,service=EJB3
2011-08-03 20:25:30,574 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultCommentDAO,service=EJB3
2011-08-03 20:25:30,574 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3
2011-08-03 20:25:30,574 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,578 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,579 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultCommentDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,579 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,588 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.comment.DefaultCommentDAO ejbName: DefaultCommentDAO
2011-08-03 20:25:30,598 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,599 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ExperimentalAPIBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,599 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductRoleDAO,service=EJB3
2011-08-03 20:25:30,599 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=PermissionsLogicBean,service=EJB3
2011-08-03 20:25:30,599 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductLogicBean,service=EJB3
2011-08-03 20:25:30,599 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=UserLogicBean,service=EJB3
2011-08-03 20:25:30,600 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=LdapLogicBean,service=EJB3
2011-08-03 20:25:30,601 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,602 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultImpedimentDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,602 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,613 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.impediment.DefaultImpedimentDAO ejbName: DefaultImpedimentDAO
2011-08-03 20:25:30,632 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,633 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ImpedimentLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,633 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,640 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.impediment.ImpedimentLogicBean ejbName: ImpedimentLogicBean
2011-08-03 20:25:30,650 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,650 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=LicenseLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,650 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,657 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.licensing.LicenseLogicBean ejbName: LicenseLogicBean
2011-08-03 20:25:30,666 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.service.ServiceContainer
2011-08-03 20:25:30,666 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ConcurrentCounter,service=EJB3 with dependencies:
2011-08-03 20:25:30,667 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=LicenseLogicBean,service=EJB3
2011-08-03 20:25:30,674 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.licensing.concurrent.ConcurrentCounter ejbName: ConcurrentCounter
2011-08-03 20:25:30,787 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,787 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=PermalinkLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,787 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTeamDAO,service=EJB3
2011-08-03 20:25:30,787 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultReleaseDAO,service=EJB3
2011-08-03 20:25:30,787 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=UserLogicBean,service=EJB3
2011-08-03 20:25:30,787 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3
2011-08-03 20:25:30,788 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramDAO,service=EJB3
2011-08-03 20:25:30,788 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,788 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultWebReportDAO,service=EJB3
2011-08-03 20:25:30,789 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,790 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductRoleDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,790 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,797 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.permissions.DefaultProductRoleDAO ejbName: DefaultProductRoleDAO
2011-08-03 20:25:30,808 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,808 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUsersProgramsDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,808 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,816 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.permissions.DefaultUsersProgramsDAO ejbName: DefaultUsersProgramsDAO
2011-08-03 20:25:30,826 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,827 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=PermissionsLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,828 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductRoleDAO,service=EJB3
2011-08-03 20:25:30,828 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUserDAO,service=EJB3
2011-08-03 20:25:30,828 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultRoleDAO,service=EJB3
2011-08-03 20:25:30,828 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,830 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,830 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,831 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,838 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.product.DefaultProductDAO ejbName: DefaultProductDAO
2011-08-03 20:25:30,850 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,850 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=PreferencesLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,851 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,859 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.product.PreferencesLogicBean ejbName: PreferencesLogicBean
2011-08-03 20:25:30,870 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,870 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ThemeLogicBean,service=EJB3
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProgramLogicBean,service=EJB3
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=EpicLogicBean,service=EJB3
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,871 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,872 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,872 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseRankLogicBean,service=EJB3
2011-08-03 20:25:30,872 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultImpedimentDAO,service=EJB3
2011-08-03 20:25:30,873 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,874 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductProgressLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,874 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductLogicBean,service=EJB3
2011-08-03 20:25:30,874 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:30,874 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,876 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,876 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ImportLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ThemeLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SequenceLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TaskLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TeamLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=BacklogLogicBean,service=EJB3
2011-08-03 20:25:30,877 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseRankLogicBean,service=EJB3
2011-08-03 20:25:30,879 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,880 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,880 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,888 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.program.DefaultProgramDAO ejbName: DefaultProgramDAO
2011-08-03 20:25:30,897 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,898 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramEpicDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,898 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,909 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.program.DefaultProgramEpicDAO ejbName: DefaultProgramEpicDAO
2011-08-03 20:25:30,921 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProgramLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUserDAO,service=EJB3
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultThemeDAO,service=EJB3
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramDAO,service=EJB3
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=EpicLogicBean,service=EJB3
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:30,922 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,923 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,923 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUsersProgramsDAO,service=EJB3
2011-08-03 20:25:30,923 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,923 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramEpicDAO,service=EJB3
2011-08-03 20:25:30,923 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseRankLogicBean,service=EJB3
2011-08-03 20:25:30,923 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemParentHistoryEntryDAO,service=EJB3
2011-08-03 20:25:30,925 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,925 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultReleaseDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,925 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,933 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.release.DefaultReleaseDAO ejbName: DefaultReleaseDAO
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=EpicLogicBean,service=EJB3
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,944 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseRankLogicBean,service=EJB3
2011-08-03 20:25:30,947 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,947 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseRankLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,947 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,954 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.release.ReleaseRankLogicBean ejbName: ReleaseRankLogicBean
2011-08-03 20:25:30,963 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,963 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductProgramEpicDAO,service=EJB3 with dependencies:
2011-08-03 20:25:30,963 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:30,971 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.release.epic.DefaultProductProgramEpicDAO ejbName: DefaultProductProgramEpicDAO
2011-08-03 20:25:30,979 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,979 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DelegatingEpicServiceTOFinder,service=EJB3 with dependencies:
2011-08-03 20:25:30,979 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultReleaseDAO,service=EJB3
2011-08-03 20:25:30,979 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramDAO,service=EJB3
2011-08-03 20:25:30,979 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductProgramEpicDAO,service=EJB3
2011-08-03 20:25:30,980 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:30,980 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProgramEpicDAO,service=EJB3
2011-08-03 20:25:30,986 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.release.epic.DelegatingEpicServiceTOFinder ejbName: DelegatingEpicServiceTOFinder
2011-08-03 20:25:30,994 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:30,994 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=EpicLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:30,995 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,003 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.release.epic.EpicLogicBean ejbName: EpicLogicBean
2011-08-03 20:25:31,021 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.release.ReleaseLogicBean ejbName: ReleaseLogicBean
2011-08-03 20:25:31,035 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,035 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ActualsReportLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,035 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3
2011-08-03 20:25:31,036 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultSprintDAO,service=EJB3
2011-08-03 20:25:31,036 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskHoursSpentDAO,service=EJB3
2011-08-03 20:25:31,037 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,038 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=BurndownReportLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,038 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,041 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.report.burndown.BurndownReportLogicBean ejbName: BurndownReportLogicBean
2011-08-03 20:25:31,048 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,049 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultCycleTimeCreator,service=EJB3 with dependencies:
2011-08-03 20:25:31,049 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ReleaseLogicBean,service=EJB3
2011-08-03 20:25:31,049 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:31,049 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:31,054 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.report.cycletime.DefaultCycleTimeCreator ejbName: DefaultCycleTimeCreator
2011-08-03 20:25:31,061 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,061 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=HoursByThemeLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,061 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultThemeDAO,service=EJB3
2011-08-03 20:25:31,061 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultReleaseDAO,service=EJB3
2011-08-03 20:25:31,061 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:31,061 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskHoursSpentDAO,service=EJB3
2011-08-03 20:25:31,063 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,063 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=EpicReportLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,063 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,067 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.report.release.epicprogress.EpicReportLogicBean ejbName: EpicReportLogicBean
2011-08-03 20:25:31,074 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,074 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintReportLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,074 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,079 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.report.sprint.SprintReportLogicBean ejbName: SprintReportLogicBean
2011-08-03 20:25:31,086 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,086 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=UserLoadReportLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,086 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=ProductLogicBean,service=EJB3
2011-08-03 20:25:31,087 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,088 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,089 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultSprintVelocityDataCollector,service=EJB3 with dependencies:
2011-08-03 20:25:31,089 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=BacklogLogicBean,service=EJB3
2011-08-03 20:25:31,089 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3
2011-08-03 20:25:31,091 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,091 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=LoginConfigurationLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,094 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.security.LoginConfigurationLogicBean ejbName: LoginConfigurationLogicBean
2011-08-03 20:25:31,100 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,100 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultSprintDAO,service=EJB3 with dependencies:
2011-08-03 20:25:31,100 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,106 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.sprint.DefaultSprintDAO ejbName: DefaultSprintDAO
2011-08-03 20:25:31,113 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,113 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskHoursSpentDAO,service=EJB3 with dependencies:
2011-08-03 20:25:31,114 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,119 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.sprint.DefaultTaskHoursSpentDAO ejbName: DefaultTaskHoursSpentDAO
2011-08-03 20:25:31,132 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.report.hoursbytheme.HoursByThemeLogicBean ejbName: HoursByThemeLogicBean
2011-08-03 20:25:31,140 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,140 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=SprintDefinitionLogicBean,service=EJB3 with dependencies:
2011-08-03 20:25:31,140 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTeamDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultUserDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=TaskLogicBean,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultBacklogItemDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultProductDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskHoursSpentDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskEstimateDAO,service=EJB3
2011-08-03 20:25:31,141 INFO [org.jboss.ejb3.JmxKernelAbstraction] jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultSprintDAO,service=EJB3
2011-08-03 20:25:31,143 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,143 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskDAO,service=EJB3 with dependencies:
2011-08-03 20:25:31,143 INFO [org.jboss.ejb3.JmxKernelAbstraction] persistence.units:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,unitName=ScrumWorks
2011-08-03 20:25:31,151 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.task.DefaultTaskDAO ejbName: DefaultTaskDAO
2011-08-03 20:25:31,164 INFO [org.jboss.ejb3.EJBContainer] STARTED EJB: com.danube.scrumworks.report.actuals.ActualsReportLogicBean ejbName: ActualsReportLogicBean
2011-08-03 20:25:31,172 INFO [org.jboss.ejb3.JmxKernelAbstraction] creating wrapper delegate for: org.jboss.ejb3.stateless.StatelessContainer
2011-08-03 20:25:31,172 INFO [org.jboss.ejb3.JmxKernelAbstraction] installing MBean: jboss.j2ee:ear=ScrumWorks-5.0.0.ear,jar=ScrumWorksEJB3.jar,name=DefaultTaskEstimateDAO,service=EJB3 with dependencies:
this problem
