I have just installed Scrumworks Basic on a Win2008 R2 box. I has downloaded and installed Java. The only other thing on the machine so far is my SVN server (which is working fine on port 88) and I have checked that nothing else is using port 8080 (using netstat -an). When I try to start scrunworks service I get the 1067 error.
Any ideas?
Many thanks in advance
Steve
"System error 1067" when trying to start scrum works for the first time
Hi Steve,
I'm not entirely sure what your error may be related to, from what I can find System error 1067 can be pretty generic from application to application. In our case I just finished searching through past cases and couldn't find a record of it ever having been reported to us.
You might be able to find a clue as to why this is happening in the log file, located at: installdirectory\server\scrumworks\log\server.log
The only solid thing that I know of that may be causing the issue is that Windows 2008 is not a supported platform:
http://www.danube.com/docs/scrumworks...
Running on a supported platform may resolve the issue. If nothing jumps out at you in the server.log as being an obvious problem (such as a port conflict) you will want to try installing ScrumWorks Basic on a supported platform and see if that fixes this. -
The file installdirectory\server\scrumworks\log\server.log does not exist. But I do have a boot.log
I have installed to c:\scrumworks as my install folder.
Are you using MySQL behind the scenes? If so, what ports are you using server side as this might be what is conflicting.
I removed the file and tried to restart the service and this is the contents of the fresh boot.log file.
07:56:07,938 INFO [Server] Starting JBoss (MX MicroKernel)...
07:56:07,938 INFO [Server] Release ID: JBoss [Zion] 4.0.4.GA (build: CVSTag=JBoss_4_0_4_GA date=200605151000)
07:56:07,938 DEBUG [Server] Using config: org.jboss.system.server.ServerConfigImpl@cec0c5
07:56:07,938 DEBUG [Server] Server type: class org.jboss.system.server.ServerImpl
07:56:07,938 DEBUG [Server] Server loaded through: org.jboss.system.server.NoAnnotationURLClassLoader
07:56:07,938 DEBUG [Server] Boot URLs:
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/endorsed/resolver.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/endorsed/serializer.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/endorsed/xalan.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/endorsed/xercesImpl.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/endorsed/xml-apis.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/jboss-jmx.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/dom4j.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/jaxen.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/concurrent.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/log4j-boot.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/jboss-common.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/jboss-system.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/jboss-xml-binding.jar
07:56:07,938 DEBUG [Server] file:/C:/Scrumworks/lib/namespace.jar
07:56:07,938 INFO [Server] Home Dir: C:\Scrumworks
07:56:07,938 INFO [Server] Home URL: file:/C:/Scrumworks/
07:56:07,938 DEBUG [Server] Library URL: file:/C:/Scrumworks/lib/
07:56:07,938 INFO [Server] Patch URL: null
07:56:07,938 INFO [Server] Server Name: scrumworks
07:56:07,938 INFO [Server] Server Home Dir: C:\Scrumworks\server\scrumworks
07:56:07,938 INFO [Server] Server Home URL: file:/C:/Scrumworks/server/scrumworks/
07:56:07,938 INFO [Server] Server Log Dir: C:\Scrumworks\server\scrumworks\log
07:56:07,938 DEBUG [Server] Server Data Dir: C:\Scrumworks\server\scrumworks\data
07:56:07,938 INFO [Server] Server Temp Dir: C:\Scrumworks\server\scrumworks\tmp
07:56:07,938 DEBUG [Server] Server Config URL: file:/C:/Scrumworks/server/scrumworks/conf/
07:56:07,938 DEBUG [Server] Server Library URL: file:/C:/Scrumworks/server/scrumworks/lib/
07:56:07,938 INFO [Server] Root Deployment Filename: jboss-service.xml
07:56:07,938 DEBUG [Server] Starting General Purpose Architecture (GPA)...
07:56:08,078 DEBUG [Server] Created MBeanServer: org.jboss.mx.server.MBeanServerImpl@17a8a02[ defaultDomain='jboss' ]
07:56:08,094 DEBUG [Server] Boot url list: [file:/C:/Scrumworks/server/scrumworks/conf/]
07:56:08,094 DEBUG [Server] Creating loader for URL: file:/C:/Scrumworks/server/scrumworks/conf/
07:56:08,109 DEBUG [RepositoryClassLoader] setRepository, repository=org.jboss.mx.loading.UnifiedLoaderRepository3@982589, cl=org.jboss.mx.loading.UnifiedClassLoader3@c88440{ url=file:/C:/Scrumworks/server/scrumworks/conf/ ,addedOrder=0}
07:56:08,109 DEBUG [UnifiedLoaderRepository3] Adding org.jboss.mx.loading.UnifiedClassLoader3@c88440{ url=file:/C:/Scrumworks/server/scrumworks/conf/ ,addedOrder=0}
07:56:08,297 DEBUG [Server] Failed to create xmbean for: org.jboss.system.server.ServerInfo
07:56:08,297 INFO [ServerInfo] Java version: 1.5.0_09,Sun Microsystems Inc.
07:56:08,297 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM 1.5.0_09-b03,Sun Microsystems Inc.
07:56:08,297 INFO [ServerInfo] OS-System: Windows NT (unknown) 6.1,x86
07:56:08,297 DEBUG [ServerInfo] Full System Properties Dump
07:56:08,297 DEBUG [ServerInfo] java.runtime.name: Java(TM) 2 Runtime Environment, Standard Edition
07:56:08,297 DEBUG [ServerInfo] jboss.server.base.dir: C:\Scrumworks\server
07:56:08,297 DEBUG [ServerInfo] java.protocol.handler.pkgs: org.jboss.net.protocol
07:56:08,297 DEBUG [ServerInfo] sun.boot.library.path: C:\Scrumworks\_jre\bin
07:56:08,297 DEBUG [ServerInfo] jboss.server.lib.url: file:/C:/Scrumworks/server/scrumworks/lib/
07:56:08,297 DEBUG [ServerInfo] java.vm.version: 1.5.0_09-b03
07:56:08,297 DEBUG [ServerInfo] javax.management.builder.initial: org.jboss.mx.server.MBeanServerBuilderImpl
07:56:08,297 DEBUG [ServerInfo] java.vm.vendor: Sun Microsystems Inc.
07:56:08,297 DEBUG [ServerInfo] java.vendor.url: http://java.sun.com/
07:56:08,297 DEBUG [ServerInfo] path.separator: ;
07:56:08,297 DEBUG [ServerInfo] java.vm.name: Java HotSpot(TM) Client VM
07:56:08,297 DEBUG [ServerInfo] file.encoding.pkg: sun.io
07:56:08,297 DEBUG [ServerInfo] user.country: GB
07:56:08,297 DEBUG [ServerInfo] sun.os.patch.level:
07:56:08,297 DEBUG [ServerInfo] java.vm.specification.name: Java Virtual Machine Specification
07:56:08,312 DEBUG [ServerInfo] user.dir: C:\Scrumworks\bin
07:56:08,312 DEBUG [ServerInfo] jboss.server.base.url: file:/C:/Scrumworks/server/
07:56:08,312 DEBUG [ServerInfo] java.runtime.version: 1.5.0_09-b03
07:56:08,312 DEBUG [ServerInfo] java.awt.graphicsenv: sun.awt.Win32GraphicsEnvironment
07:56:08,312 DEBUG [ServerInfo] java.endorsed.dirs: C:\Scrumworks\_jre\lib\endorsed
07:56:08,312 DEBUG [ServerInfo] os.arch: x86
07:56:08,312 DEBUG [ServerInfo] java.io.tmpdir: C:\Windows\TEMP\
07:56:08,312 DEBUG [ServerInfo] line.separator:
07:56:08,312 DEBUG [ServerInfo] jbossmx.loader.repository.class: org.jboss.mx.loading.UnifiedLoaderRepository3
07:56:08,312 DEBUG [ServerInfo] java.vm.specification.vendor: Sun Microsystems Inc.
07:56:08,312 DEBUG [ServerInfo] user.variant:
07:56:08,312 DEBUG [ServerInfo] os.name: Windows NT (unknown)
07:56:08,312 DEBUG [ServerInfo] jboss.bind.address: 0.0.0.0
07:56:08,312 DEBUG [ServerInfo] jboss.server.temp.dir: C:\Scrumworks\server\scrumworks\tmp
07:56:08,312 DEBUG [ServerInfo] jboss.home.dir: C:\Scrumworks
07:56:08,312 DEBUG [ServerInfo] sun.jnu.encoding: Cp1252
07:56:08,312 DEBUG [ServerInfo] java.library.path: C:\Scrumworks\bin;.;C:\Windows\system32;C:\Windows;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;
07:56:08,312 DEBUG [ServerInfo] jboss.server.home.dir: C:\Scrumworks\server\scrumworks
07:56:08,312 DEBUG [ServerInfo] java.specification.name: Java Platform API Specification
07:56:08,312 DEBUG [ServerInfo] java.class.version: 49.0
07:56:08,312 DEBUG [ServerInfo] sun.management.compiler: HotSpot Client Compiler
07:56:08,312 DEBUG [ServerInfo] jboss.server.config.url: file:/C:/Scrumworks/server/scrumworks/conf/
07:56:08,312 DEBUG [ServerInfo] os.version: 6.1
07:56:08,312 DEBUG [ServerInfo] jboss.home.url: file:/C:/Scrumworks/
07:56:08,312 DEBUG [ServerInfo] user.home: C:\
07:56:08,312 DEBUG [ServerInfo] user.timezone: GMT
07:56:08,312 DEBUG [ServerInfo] java.awt.printerjob: sun.awt.windows.WPrinterJob
07:56:08,312 DEBUG [ServerInfo] java.specification.version: 1.5
07:56:08,312 DEBUG [ServerInfo] file.encoding: Cp1252
07:56:08,312 DEBUG [ServerInfo] jboss.server.home.url: file:/C:/Scrumworks/server/scrumworks/
07:56:08,312 DEBUG [ServerInfo] jboss.server.log.dir: C:\Scrumworks\server\scrumworks\log
07:56:08,312 DEBUG [ServerInfo] user.name: HAGRID$
07:56:08,312 DEBUG [ServerInfo] java.class.path: C:\Scrumworks\_jre\lib\tools.jar;C:\Scrumworks\\bin\run.jar
07:56:08,312 DEBUG [ServerInfo] jboss.lib.url: file:/C:/Scrumworks/lib/
07:56:08,312 DEBUG [ServerInfo] jboss.server.name: scrumworks
07:56:08,312 DEBUG [ServerInfo] java.vm.specification.version: 1.0
07:56:08,312 DEBUG [ServerInfo] sun.arch.data.model: 32
07:56:08,312 DEBUG [ServerInfo] java.home: C:\Scrumworks\_jre
07:56:08,312 DEBUG [ServerInfo] java.specification.vendor: Sun Microsystems Inc.
07:56:08,312 DEBUG [ServerInfo] user.language: en
07:56:08,312 DEBUG [ServerInfo] awt.toolkit: sun.awt.windows.WToolkit
07:56:08,312 DEBUG [ServerInfo] java.vm.info: mixed mode
07:56:08,312 DEBUG [ServerInfo] java.version: 1.5.0_09
07:56:08,312 DEBUG [ServerInfo] java.ext.dirs: C:\Scrumworks\_jre\lib\ext
07:56:08,312 DEBUG [ServerInfo] jboss.server.data.dir: C:\Scrumworks\server\scrumworks\data
07:56:08,312 DEBUG [ServerInfo] sun.boot.class.path: C:\Scrumworks\_jre\lib\rt.jar;C:\Scrumworks\_jre\lib\i18n.jar;C:\Scrumworks\_jre\lib\sunrsasign.jar;C:\Scrumworks\_jre\lib\jsse.jar;C:\Scrumworks\_jre\lib\jce.jar;C:\Scrumworks\_jre\lib\charsets.jar;C:\Scrumworks\_jre\classes
07:56:08,312 DEBUG [ServerInfo] java.vendor: Sun Microsystems Inc.
07:56:08,312 DEBUG [ServerInfo] file.separator: \
07:56:08,312 DEBUG [ServerInfo] java.vendor.url.bug: http://java.sun.com/cgi-bin/bugreport...
07:56:08,312 DEBUG [ServerInfo] sun.cpu.endian: little
07:56:08,312 DEBUG [ServerInfo] sun.io.unicode.encoding: UnicodeLittle
07:56:08,312 DEBUG [ServerInfo] sun.desktop: windows
07:56:08,312 DEBUG [ServerInfo] sun.cpu.isalist:
07:56:08,312 DEBUG [Server] Created system MBean: jboss.system:type=ServerInfo
07:56:08,312 DEBUG [Server] Failed to create xmbean for: org.jboss.system.ServiceController
07:56:08,359 DEBUG [ServiceController] Controller MBean online
07:56:08,359 DEBUG [Server] Created system MBean: jboss.system:service=ServiceController
07:56:08,469 DEBUG [Server] Created system XMBean: jboss.system:service=MainDeployer
07:56:08,469 DEBUG [ServiceController] Creating service jboss.system:service=MainDeployer
07:56:08,484 DEBUG [MainDeployer] Creating jboss.system:service=MainDeployer
07:56:08,500 DEBUG [MainDeployer] Created jboss.system:service=MainDeployer
07:56:08,500 DEBUG [ServiceController] Creating dependent components for: jboss.system:service=MainDeployer dependents are: []
07:56:08,500 DEBUG [ServiceController] starting service jboss.system:service=MainDeployer
07:56:08,500 DEBUG [MainDeployer] Starting jboss.system:service=MainDeployer
07:56:08,500 DEBUG [MainDeployer] Started jboss.system:service=MainDeployer
07:56:08,500 DEBUG [ServiceController] Starting dependent components for: jboss.system:service=MainDeployer dependent components: []
07:56:08,515 DEBUG [Server] Shutdown hook added
07:56:08,562 DEBUG [Server] Created system XMBean: jboss.system:service=JARDeployer
07:56:08,562 DEBUG [ServiceController] Creating service jboss.system:service=JARDeployer
07:56:08,562 DEBUG [JARDeployer] Creating jboss.system:service=JARDeployer
07:56:08,578 DEBUG [JARDeployer] Created jboss.system:service=JARDeployer
07:56:08,578 DEBUG [ServiceController] Creating dependent components for: jboss.system:service=JARDeployer dependents are: []
07:56:08,578 DEBUG [ServiceController] starting service jboss.system:service=JARDeployer
07:56:08,578 DEBUG [JARDeployer] Starting jboss.system:service=JARDeployer
07:56:08,578 DEBUG [MainDeployer] Adding deployer: org.jboss.deployment.JARDeployer@d3db51
07:56:08,578 DEBUG [SuffixOrderHelper] Static suffix exists; ignoring request for adding enhanced suffix: 700:.jar
07:56:08,578 DEBUG [JARDeployer] Started jboss.system:service=JARDeployer
07:56:08,578 DEBUG [ServiceController] Starting dependent components for: jboss.system:service=JARDeployer dependent components: []
07:56:08,609 DEBUG [Server] Created system XMBean: jboss.system:service=ServiceDeployer
07:56:08,609 DEBUG [ServiceController] Creating service jboss.system:service=ServiceDeployer
07:56:08,609 DEBUG [SARDeployer] Creating jboss.system:service=ServiceDeployer
07:56:08,625 DEBUG [SARDeployer] Created jboss.system:service=ServiceDeployer
07:56:08,625 DEBUG [ServiceController] Creating dependent components for: jboss.system:service=ServiceDeployer dependents are: []
07:56:08,625 DEBUG [ServiceController] starting service jboss.system:service=ServiceDeployer
07:56:08,625 DEBUG [SARDeployer] Starting jboss.system:service=ServiceDeployer
07:56:08,625 DEBUG [MainDeployer] Adding deployer: org.jboss.deployment.SARDeployer@e61fd1
07:56:08,625 DEBUG [SARDeployer] Started jboss.system:service=ServiceDeployer
07:56:08,625 DEBUG [ServiceController] Starting dependent components for: jboss.system:service=ServiceDeployer dependent components: []
07:56:08,625 INFO [Server] Core system initialized
07:56:08,640 DEBUG [MainDeployer] Starting deployment of package: file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:08,640 DEBUG [MainDeployer] Starting deployment (init step) of package at: file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:08,640 DEBUG [MainDeployer] Copying file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml -> C:\Scrumworks\server\scrumworks\tmp\deploy\tmp37856jboss-service.xml
07:56:08,640 DEBUG [MainDeployer] using deployer org.jboss.deployment.SARDeployer@e61fd1
07:56:08,765 DEBUG [SARDeployer] Found classpath element: [classpath: null]
07:56:08,765 DEBUG [SARDeployer] codebase URL is file:/C:/Scrumworks/server/scrumworks/lib/
07:56:08,765 DEBUG [SARDeployer] listing codebase for archives matching *
07:56:08,765 DEBUG [SARDeployer] URLLister class is org.jboss.net.protocol.file.FileURLLister
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/activation.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/antlr-2.7.6.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/autonumber-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/bcel.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/bindingservice-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/bsf.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/bsh-1.3.0.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/bsh-deployer.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/cglib.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/commons-collections.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/commons-httpclient.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/commons-logging.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/hibernate3.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/hsqldb-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/hsqldb.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/javassist.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/javax.servlet.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/javax.servlet.jsp.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-backport-concurrent.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-common-jdbc-wrapper.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-hibernate.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-j2ee.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-jaxrpc.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-jca.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-jsr77.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-jsr88.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-management.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-monitoring.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-remoting-int.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-remoting.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-saaj.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-serialization.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-srp.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss-transaction.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jboss.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jbossmq.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jbossretro-rt.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jbosssx.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jmx-adaptor-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jnpserver.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jpl-pattern.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/jpl-util.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/log4j.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/mail-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/mail.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/properties-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/scheduler-plugin-example.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/scheduler-plugin.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/snmp-support.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/wsdl4j.jar
07:56:08,781 DEBUG [SARDeployer] deployed classes for file:/C:/Scrumworks/server/scrumworks/lib/xmlentitymgr.jar
07:56:08,781 DEBUG [SARDeployer] about to copy 0 local directories
07:56:08,781 DEBUG [SARDeployer] looking for nested deployments in : file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:08,781 DEBUG [DeploymentInfo] createLoaderRepository from config: LoaderRepositoryConfig(repositoryName: JMImplementation:service=LoaderRepository,name=Default, repositoryClassName: null, configParserClassName: null, repositoryConfig: null)
07:56:08,781 DEBUG [RepositoryClassLoader] setRepository, repository=org.jboss.mx.loading.UnifiedLoaderRepository3@982589, cl=org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=0}
07:56:08,781 DEBUG [UnifiedLoaderRepository3] Adding org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=0}
07:56:08,796 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/activation.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,843 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/antlr-2.7.6.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,843 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/autonumber-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,890 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/bcel.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,890 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/bindingservice-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,906 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/bsf.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,937 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/bsh-1.3.0.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,937 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/bsh-deployer.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,937 DEBUG [ClassLoaderUtils] Multiple class loaders found for pkg:
07:56:08,968 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/cglib.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:08,999 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/commons-collections.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,031 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/commons-httpclient.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,031 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/commons-logging.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,171 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/hibernate3.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,171 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/hsqldb-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,234 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/hsqldb.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,281 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/javassist.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,296 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/javax.servlet.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,296 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/javax.servlet.jsp.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,312 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-backport-concurrent.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,327 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-common-jdbc-wrapper.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,327 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-hibernate.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,359 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-j2ee.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,359 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-jaxrpc.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,390 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-jca.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,390 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-jsr77.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,390 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-jsr88.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,406 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-management.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,406 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-monitoring.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,406 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-remoting-int.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,468 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-remoting.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,468 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-saaj.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,484 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-serialization.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,484 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-srp.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,484 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss-transaction.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,640 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jboss.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,671 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jbossmq.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,671 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jbossretro-rt.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,702 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jbosssx.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,702 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jmx-adaptor-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,702 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jnpserver.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,702 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jpl-pattern.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,702 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/jpl-util.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,718 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/log4j.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,733 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/mail-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,749 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/mail.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,749 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/properties-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,749 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/scheduler-plugin-example.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,749 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/scheduler-plugin.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,765 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/snmp-support.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,780 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/wsdl4j.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,780 DEBUG [RepositoryClassLoader] Added url: file:/C:/Scrumworks/server/scrumworks/lib/xmlentitymgr.jar, to ucl: org.jboss.mx.loading.UnifiedClassLoader3@baa466{ url=null ,addedOrder=2}
07:56:09,780 DEBUG [MainDeployer] found 0 subpackages of file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:09,780 DEBUG [MainDeployer] Watching new file: file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:09,780 DEBUG [MainDeployer] create step for deployment file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:09,780 DEBUG [SARDeployer] Deploying SAR, create step: url file:/C:/Scrumworks/server/scrumworks/conf/jboss-service.xml
07:56:09,780 DEBUG [SARDeployer] Registering service UCL=jmx.loading:UCL=baa466
07:56:09,780 DEBUG [ServiceCreator] About to create bean: jboss.management.local:j2eeType=J2EEDomain,name=Manager with code: org.jboss.management.j2ee.LocalJBossServerDomain
07:56:09,827 DEBUG [ServiceCreator] Created bean: jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,827 DEBUG [ServiceConfigurator] MainDeployer set to jboss.system:service=MainDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,827 DEBUG [ServiceConfigurator] SARDeployer set to jboss.system:service=ServiceDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] EARDeployer set to jboss.j2ee:service=EARDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] EJBDeployer set to jboss.ejb:service=EJBDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] RARDeployer set to jboss.jca:service=RARDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] CMDeployer set to jboss.jca:service=ConnectionFactoryDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] WARDeployer set to jboss.web:service=WebServer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] CARDeployer set to jboss.j2ee:service=ClientDeployer in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] MailService set to jboss:service=Mail in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] JMSService set to jboss.mq:service=DestinationManager in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] JNDIService set to jboss:service=Naming in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,843 DEBUG [ServiceConfigurator] JTAService set to jboss:service=TransactionManager in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,858 DEBUG [ServiceConfigurator] UserTransactionService set to jboss:service=ClientUserTransaction in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,858 DEBUG [ServiceConfigurator] RMI_IIOPService set to jboss:service=CorbaORB in jboss.management.local:j2eeType=J2EEDomain,name=Manager
07:56:09,858 DEBUG [ServiceCreator] About to create xmbean object: jboss:service=AttributePersistenceService with code: org.jboss.system.pm.AttributePersistenceService with descriptor: resource:xmdesc/AttributePersistenceService-xmbean.xml -
No, ScrumWorks Basic does not use MySQL.
ScrumWorks Pro however can optionally use MySQL.
At this point I don't know what to recommend aside from installing on a platform that we know to work. -
I have done a bit of searching. It seems that Scrumwoks is using a version of JBoss that is from 2006. I wonder if this is related to the error that I am having,
http://community.jboss.org/message/535671
Unfortunately I don't have access to a 2003 or below server and running it from my laptop is not a viable solution (anyway, that's windows 7 which isn't listed either) http://danube.com/docs/scrumworks/lat...
I'm guessing Scrum works pro has the same limitations as the basic version in terms of OS?
Steve -
Hi Steven,
No, ScrumWorks Pro does not. This will probably make more sense to you with a bit of history on the two products. ScrumWorks Basic is release 1.8.4, development stopped on it back in 2007 when Pro was released. We are currently on ScrumWorks 4.3.
ScrumWorks Pro is a pretty different product at this point.
Unfortunately this is one of the reasons we don't officially support Basic, all of the development resources go into updating the Pro version and Basic is pretty much left As-is. It makes answering questions like this a bit rough at times.
I believe there are plans to update Basic (since it is just getting too old to work properly for some customers) but I don't have a timeline on when that might happen. -
